Ana içeriğe geç
LCD does not get Power
Macbook was stepped on in the left upper keyboard area by the hinge to LCD. The LCD did not crack. The Macbook still drives an external monitor fine with everything working. The monitor is just pitch black. Unsure if the inverter was damaged or some cable assembly that goes to the display. Any ideas or troubleshooting advice is appreciated.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You most likely have a damaged cable. Could be the display data cable or the inverter cable. You will need to open it and visually examine the cables and connections. Here's a very good place to start.
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Display Data Cable Replacement
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
kenkaufman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 541
