Black screen with sound and green light
I recently changed the screen/digitizer but there is nothing but only a sound from the alarm clock. How do I make the screen turn on? everything is black on display.
thank you :)
Bu iyi bir soru mu?
thank you :)
Bu iyi bir soru mu?
Chances are screen is not connected properly, the ribbon cable that plugs between the logic board and the screen cable may be damaged.
Or at worst, the screen is faulty.
Bu yanıt yardımcı oldu mu?
I've had this happen a few times after a screen replacement. Always do a hard reset first, most the time it will fix this issue. If not the it's the connection of the flex cables to the board itself and or a faulty replacement screen.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 847
