Ana içeriğe geç
How to Set up D-Link DIR 600
I have purchased new router D-Link DIR600 and I have already inserted internet cable in to router port but I have done all setting but still ip configuration problem showing.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
When you plug your computer into the cable modems Ethernet port are you able to connect to the internet? If you can, your problem is the default gateway setting in your D-Link is not set to the cable modems IP address.
We use the term 'Bad Gateway' as the direction of the next hop is not known.
Think of it this way... You're on the shore of a large lake, looking out you can't see the other shoreline on the other side so you don't know if its there or not. But, if your friend got into a boat and went half way where he can see both you and the distant shoreline he could relay your signal. Thats the problem here.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
David Den sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 822
