How much would it cost to repair my charging port that doesnt charge all
It doesnt charge and when i put the Charger in a small piece fell out of the charging port
Bu iyi bir soru mu?
Bu iyi bir soru mu?
well you can take it to a local repair shop. Most shops will charge between 70-100$ CAD to replace a charge port on that model.
Bu yanıt yardımcı oldu mu?
what if you have rice stuck all the way in the back of the charging port how much to get that fixed for a 6s or is there a way to get that out
O.k, you have a grain of rice stuck in your tablet's or phone's charge port. Here's what you need to do!
Get a flashlight, a stick pin, and glasses if you wear them, you don't want to touch or ruin a delicate part inside of that tiny hole. Shine the flashlight straight into the port, take the pin, "preferably a long stick pin" then go ahead and try to poke the grain, and bring it out, that simple. Or use a suction method.
GOOD LUCK!
S B
It varies, if the cost to repair the charging port is higher than the original cost of your tablet, I suggest purchasing a new one. The costs of tablets are not expensive as they used to be. Now days you can get a decent tablet for $99-$200, but that depends on the brand, style, and gigabyts, 4,8,16,32,64, and up. And always get a second, maybe even a third opinion, when it comes to getting something repaired, there are scammers out to RIP you off!
GOOD LUCK!
S B
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 40
Her zaman: 17,583
how can I fix mine bc its not working
lisacoleharris tarafından
I cant get mine to do anything it just wont charge , it use to go on and off
clementsmary57 tarafından
When i plug into the port the bell sounds. But as soon as I let go; the charging signal disappears. I cant get the plug to hold onto the inside of the phone i guess?
peterjmic tarafından
Hi, wanted to ask how much would it cost to fix a charging port on a Samsung device please
adrian ashworth tarafından
Hi @ adrian ashworth
What is the model number of the device?
jayeff tarafından
