Non-Functioning Shift Control Option keys on replaced keyboard
Water damaged 2012 MacBook Air 13". Keyboard was replaced. Everything runs perfectly fine except the (left side) Shift Control and Option keys don't work.
Things I've tried so far:
- Updated all preferences and upgraded to OS X High Sierra
- Reset the NVRAM
- Reset SMC using "unplug battery/hold power button" method (can't use "Shift/Control/Option/Power button" method, obviously)
- Ran Disk Permissions
- Ran Apple Hardware test (no issues found)
- Booted up in Safe Mode
- Double-checked that Mouse Keys, Sticky Keys and Slow Keys were not enabled under Accessibility
This seems to be an issue without a solution over many years. Reaching out to see if anyone found a solution short of board level repair. Thanks in advance for any responses.
Bu iyi bir soru mu?
2 Yorum
I have the same problem with the 3 left side keys not working - shift, control and option. Tried all of the above but doesn't help.
Can anyone advise what is required, new keyboard, trackpad or upper body?
Pablo tarafından
I have the same problem and have no idea how to fix it. We possibly think the problem started when we updated to Mojave
Emila tarafından
