How to repair broken LCD Screen
Amigos,
LCD screen of my iPhone(A1203 - 1st Gen) is damaged and I need a new one.
I can't locate this info on ifixit.com. Any pointers?
cheers,
Rocky
Bu iyi bir soru mu?
Amigos,
cheers,
Rocky
Bu iyi bir soru mu?
Here's how to fix it: iPhone 1st Generation Display Assembly Replacement
The part is not cheap, I'd do a lot of searching for prices before trying to fix it: http://www.idemigods.com/iPhone_1st_Gen_...
Bu yanıt yardımcı oldu mu?
http://www.rapidrepair.com/shop/4120-lcd... little cheaper and the least expensive on ebay at http://cgi.ebay.com/iPhone-1st-Gen-2G-LC... so it pays off to shop around :) good luck
I've done this repair and it's a lot of work. You have to open the iPhone from the back to replace it. While you can buy the whole display assembly I did it with just purchasing the touch digitizer. It's a little more difficult but will save you $40. Shop around on eBay for the touch screen. Don't buy from China on this one. Read through the step by step on how to remove the display assembly and then check out youtube videos on how to separate the touch digitizer from the main display assembly. You're gonna need a hair dryer and one of the plastic pry tools. You can do it. I did that as the first thing I'd ever done on an iPhone. Take it slow when disassembling don't rush things. If something isn't coming easy don't pull harder. I did and tore a ribbon cable. Best of luck!
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 9,258
