Nissan Dayz not picking up
I have 2014 Nissan Dayz 660cc automatic CVT gear. I have put wrong transmission fluid. Then started pick up issue. The engine check light came and catalytic converter choked had to replaced it Then had replaced whole gear box. Now it does not pick up. I have checked up throttle body, pedal, MAP sensor, plugs still the same pickup issue.
Bu iyi bir soru mu?
2 Yorum
I have nissan dayz roox 2015 and in this car i am facing 2 problem 1 a/c not properly working when i press break padal on drive mood continues on and off compressor. 2nd problem is pick is also very bad on ac and petrol average also. Without ac petrol average maximum give 19km/l very softly drive not any where stop...
Arslan Dar tarafından
My dayz car in become indicated on the dashboard check engine then i checked by diagnosis tool after showed DTC
(P0138 & P0171) i am thinking should i replacing oxygen sensor bank 1 ?
Please explain to me
m.akramauto tarafından
