Ana içeriğe geç
The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
Is this water damage?
I can’t remember spilling anything on it and this Mac is somewhere around 3-4 years old. Model number A1466
So here’s the story. One time I was on my Mac (at the time running macOS.) and suddenly it just shut down without warning while on the charger and not like hibernate and save your data, it completely turned off. Confused, I booted it up again only to see “no hardware” and no WiFi. But I had Bluetooth just fine. I tried reinstalling Mac, resetting network settings, calling Apple (“bring it in!” Obviously) so then I eventually was able to connect using a USB to Ethernet adapter but only that way. (It was so slow at 10mb/s it was a wii connect adapter!) but after a while we lost that adapter and I ordered a new airport card. Same problem even with airport card replaced.
So It sat in my room gathering dust for 3 or 4 months. Then we bought a USB WiFi adapter from staples. It is not compatible with Mac OS I fed up with all these problems, I install Windows 10. And it works fine (not the airport the WiFi usb) it’s kind of annoying sticking out. In between then and now I replaced the clutch on the MacBook successfully with no issues. Skip forward a bit to today. I opened my Mac to see if I could try to fix the airport card, which still does have Bluetooth, and notice the colorful screw holes. I’m pretty sure that is not normal.
I got some halfway decent photos.
Sorry if there are duplicates.
this is more of a question for @oldturkey03 or @mayer
thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
9 Yorum
it appears that there is a screw missing from the hole and from the scratches on the torx head in the upper left, someone has been inside the computer. Not sure about the water damage because I do not see any kind of deposits or discoloration of the breadboard or the electronic components.
tarafından
Oh I removed the screw for the picture =p
tarafından
So the weird color stuff around the screw holes are normal?
tarafından
Maybe this is normal. Is this normal @mayer?
tarafından
also @lutherhaynes good eye seeing that scratch! I have done repairs in the laptop as mentioned in the quedtion
tarafından
4 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Looking at all the pics, there is discoloration around many of the holes, also in the pic with the screw driver, upper left, toward the middle, see the discoloration on the board, it looks like it is faded, and the IC chips near it and the other one to the right looks like they are faded. That's is what is weird because there is no deposits in the connectors or near the capacitors (caps would discharge and would show signs of burns) that are clustered together.
The discoloration looks like the copper plating has come into some sort of disruption and had overheated or cooked like a high moisture content.
That's weird that there is several spots that has this.
Bu yanıt yardımcı oldu mu?
Puan 1
7 Yorum:
so overheating? Water damage? Or both. This question turns out to me more complicated tha I thought.
tarafından
it is possible that the water damage came first if it is the case. The overheat comes second because electricity follows the path of least resistance. The discoloration could be caused from the overheating, regardless of how slight. Those contacts on the screws are really thin and it would not take much to cause them to discolor. Think of them being like the old thermostat coil metal, slight change of heat or cold causes them to contort.
tarafından
All in all, it is fixable.
tarafından
Where would the water have come from? I never spilled anything on it...
tarafından
I didn't say that you spilled anything on it. I'm just trying to place logic on it.
These are micro circuits and it doesn't take much heat, moisture or static electricity to disrupt a circuit.
Check the contacts on the airport card and see if they need to be cleaned or look to see of they have scrapes or tracks on them. You might want to check the grounding using a sweep meter or an oscillator meter if you have one. It seems like there might be a loss of grounding since there are more than one grounding screw cotact is discolored.
tarafından
2 tane daha yorum göster
Yorum Ekle
I think it's the socket contacts rusted, you may scrape the contacts clean.
Puan 0
2 Yorum:
Hmm... maybe take a look in the socket connected the airport card. see if its gunked up. I'll get back to you soon on that.
tarafından
No Luck =( Thanks Though!
tarafından
Yorum Ekle
Yanıtını ekle
Aiden sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,768
