Folder with flashing? after inserting new drive with adapter
Hello, then I boot from usb (High Sierra) Disk utility see my new drive without any issues, its able to run aid and format partitions and then i select install its take arround 20 minutes for it but after restart it try to restart from flash again, if I remove it - got folder with flashing ? - tryed R - its load from internet an image and run similar tool (but from el captain os) and this tool cant see my drive. Also I cant make it bootable even then boot from High Sierra. Any advice? Something to update perhaps on macbook?
drive is Samsung MZVPV256HDGL Link to ebay
adapter (link)
toolset used (link)
Bu iyi bir soru mu?
4 Yorum
Hi Kvark LT, try checking your Samsung MZVPV256HDGL with apple diagnostic tool first, you may also perform extended test to your computer.
Let us know the results.
Augustine tarafından
Your SSD's specs: Samsung MZVPV256HDGL M.2 SSD
Dan tarafından
Thanks Dan, ITs new and its working 100% - question is that I need to change in configuration (new macbook user :)) to make it start from this disk. Then I boot from Hight Sierra usb flash - disk is visible and disk tool dont have any complains. I am windows user, its sounds for me like i should mark partition to be bootable? But not sure how to do that in macos
Kvark tarafından
Th installer would have set the internal drive as the boot. If it didn’t or couldn’t then you’ll need to start the system without the external and press and hold the option key to get the boot manager to then select the internal drive. Once you’re running go into prefs and alter the startup disk setting. That should fix that. If not the adapter is bad.
Dan tarafından
