Ana içeriğe geç
Released August 2013. Identified by model number Z796C
How can I fix stuck on white screen
Stuck on white screen
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
6 Yorum:
You will need to supply more details. like, Did you attempt to fix anything on it recently? did you drop it? did it get liquid damage?
tarafından
Dropped it and waited on it to die. Still on white screen
tarafından
Hi @hogan77 ,
try removing and then replacing the battery and check if this resets the phone
tarafından
I have the same problem but I didn't drop it the ZTE powered by Android screen comes on fine but then go straight to all white idk what to do please help
tarafından
My ZTE Majesty is also doing this, after a day and a half of a white screen it just decided to work for me... I've had this phone for 17 days and the return policy only allows 15 days to return electronics... Figures.
tarafından
1 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
A white screen could be caused by a loose led connection. You need to take it apart and check screen commection.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Brandon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 3,153
