How can I remove unfortunately system ui has stopped working
How can I remove unfortunately system ui has stopped working but won't let me do anything else. Like log onto the phone
Bu iyi bir soru mu?
Bu iyi bir soru mu?
WARNING: Use caution when undertaking this process. One wrong selection can wipe your phone.
Ive had this same phone since it came out and needed to do this once. Still kickin
Bu yanıt yardımcı oldu mu?
None of these menus show up on sony xperia. Because it only blinked instead of something coming up at all. When I let go of the buttons it just started as normal again. Maybe it works better on android devices more similar to Samsung?
none of that showed up on my phone it just says safe mode
What if Recovery is not an option? Only have the following: Continue Power Up, Safe mode, USB debug mode, Factory data reset, Wipe cache, and Power down. Which of these, if any, should I choose. Thanks!
I'm just guessing but maybe "Wipe cache" is the same one? I'm no expert, just sounds logical to me based on the words. :)
i wipe the cache clean before my screen went blank still nothing very BAD BAD advise
To get back in from the black screen system ui provides press button and volume button together.This does not solve the problem just gets you back into the tablet.
Should say power button
Please explain the process that worked for you....
Screen is black how can I do setting and no display
I had the same problem but now I solved it myself, it appears to me that no one talks about this method and they tell you to go to settings and blah blah blah!! They do not understand that the screen is black and cannot see anything! Others wants you to do a factory reset and cause you to lose your precious data! I have fully recovered my phone without any data loss!
I don't know why but I have posted whole method but its not showing it
can you please tell me how you did it? I am having the same issue with my samsung.
My desktop is showing me that error UI has quit working how do I fix that
Sir. M having same issue pls tell me . How can solve this problem pls pls pls 🙏
I had the same problem. but by trying to hold different buttons at the same time my phone restarted, and by doing that it fixed it.
only for the hard rest on power on batan and the waliam batan ap ya down open this next page enter option rest and next option no…no..no.yah yes option batan canfam batan yes rest starting……….. thanx for view
I you seem like it's messing up my phone it's always cutting on and off of blinking and then cutting off all the way I'm going to black screen and making me try to reset my phone
Is I you messing my phone up it seem like it's messing my phone up it keeps cutting off and on and blinking
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 37
Her zaman: 39,003
9 Yorum
What is the name of the app?
The link doesn't work on the computer.
Berit Kleiva Møller tarafından
The dose not work I can't download any thing or delete no thing work just the sentence unfortunately the system UI has stopped
Sabah Arslan tarafından
How do I correct the ui malfunction on my straight talk service phone. It says it's stopped working and then a clock symbol says wait. It keeps showing up. I really don't wanna data reset my phone!
Jeanette Overman tarafından
My Tablet RCA say “Unfortunately System Ul has stopped. What can I do?
caram1939 tarafından
Turn phone/ tablet off. INSTALL AN SD CARD .The Ui system stops working because it is overloaded with work, The SD card should take some of your files and apps. It chooses but you can ask it to take. more apps. When you turn phone on this process should start and Ui should be better
Marjorie De'Ath tarafından
4 tane daha yorum göster
