Ana içeriğe geç
The Honor 3C is an Android smartphone produced by Huawei and released in December 2013 for 3G, April 2014 for 4G, and August 2014 for 3C Play. The Honor 3C can be identified by model numbers H30-T00 and H30-U10.
My phone is not charging through charging port
My honor 3c is not charging through charging port. Battery, charger, cable and charging port are good no fault what so ever. Don't understand what's the problem is it the charging problem on main board please do tell.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
4 Yorum:
Hi,
When you say that the charging port is good, can you connect the phone to a PC successfully via the port?
If not, have you checked the charging port using a strong light and a magnifying glass to see that the port enclosure is free of dust or lint and that all the pins are there and that they are straight and parallel with each other?
Also does the port feel "loose" when you plug in the cable and very gently (stress gently) try to move the cable plug from side to side or up and down?
tarafından
Hi my mate 10 also cant be charge,, i need to restart the phone few times to charge it..and my phone just bought for 8 month
tarafından
My honar 7c is not charg in orginal charger
tarafından
Hi @ Komalsaeed Komalsaeed,
Does it charge when using another compatible charger or when connected to a computer?
If so then there may be a problem with the original charger.
If it also doesn't charge with other chargers etc, have you checked the charging port using a strong light and a magnifying glass to see that the port enclosure is free of dust or lint and that all the pins are there and that they are straight and parallel with each other?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
You most likely need a new charging port
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
efran fazal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 14
Her zaman: 1,524
