Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
Dead iPhone 6 after infinite boot loop
So i recently started having issues with my iphone 6 , screen was replaced months ago professionaly and it started working for about 4 months. After that i noticed it would lose battery all of a sudden from 100 to 70 then turn off and display low battery logo. I kept using it like that u till i dropped it again and had issues with my screen. So i replaced it again along with battery and it was stuck in a infinite loop, i tried itunes to restore it and everything would go good until it tried to boot it would stay on the infinite loop , well while messing with it i dropped it again and now i have zero power , no charging icon , no itunes , zero response like if its dead. Anyone else experience this? What can it be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
I’m having similar issues with 2 6 plus’ i have. It sounds like for you, something dislodged from the board when you dropped it. Which means it could be a board level problem.
But before we think that, have you checked all the connectors? I would disconnect the battery(always first), then disconnect your screen, check the volume button and power button connectors. Disconnect them and reconnect them. Then inspect the ribbon cable near the battery connector. That is what provides power to your board from the lightning connector. Disconnect that and reconnect it. Then I would proceed with reassembly; plug your screen back in, and then plug your battery in and turn on.
If still nothing, maybe try to power cycle it, or recalibrate the battery. To do that, disconnect the battery, then press the power button and home button for about 20 seconds or longer to drain all the power, then reconnect battery and plug in for a few mins to the wall, not the computer. Let charge for a little and see what happens.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
cadillacthischevy2001 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 367
