Ana içeriğe geç
{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
276 Soru Tümünü görüntüle
Is there a way to disable battery charging MacBook Pro 2017 TouchBar?
Hi
I have a question is there an option to disable battery charging by software or hardware.
I remember Macbook Pro Unibody 2011 magsafe plug - if you cover the middle pin the battery will no charge, and only the power from the socket will go trough and power the laptop - I used that method when I had that model.
Bu t now I have Macbook Pro 2017 TouchBar and I bought Baseus cable kind of magsafe plug but it has only 5 pins, I tried all variation to cover each pins and all combination, but not success, As I'm not electrician guy I can't test it further.
So my question if some one has that kind of Macbook and Baseus AC Cable with magnetic plug can you test it
Thanks to all
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
5 Yorum:
Any one can help me with my question
tarafından
Please does anyone can help me with my question?
tarafından
Hi again is there anyone...?
tarafından
What kind of Baseus AC Cable did you get and why?
tarafından
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
I am sorry since there is only a poor idea that I can give you about this which is to open up the your macbook and disconnect the battery from the motherboard. From there on, your mac will work 100% dependent on the DC power supply, which is also inconvenient if the charger is disconnected your mac will turn off.
What I also wonder is why do you want to do that in the first place? Is it about the battery cycle?
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Here I'm also interested in the subject. It is an issue of battery cycles in my case, limited to a thousand before battery performance starts to decline in recent models of Mac book. I'm a heavy user of my laptop and need to charge it twice a day. That only gives about a year and a half before battery starts to decline. I used to remove the battery of my HP laptop during the day, hence that laptops battery is 5+ years old and still in good shape.
tarafından
Yorum Ekle
I am especially interested in the question, how to turn off charging, because:
I want to be able to unplug the charging cable whithout cutting the current with the physical connection by doing this. I think after x time unplugging with a “lightning” in the plug, the plug will be burned out.
Similar to the programm Jettison, that allows me to eject external discs before going to sleep, I would like to have the possibility to turn off charge, may be for 30 minutes or so, or to stop it until the battery is discharged to let’s say 40% (needs to be defined. Both would help.
Please programmers, work on that!
Thank you Andreas
Puan 0
Yorum Ekle
(Sorry for my very bad english xD) Unfortunately it is not possible to disable charging. But if your MacBook is charged to 100 percent the system automaticly stops charging so your battery doesnt get damaged over time. I have the same problem because my MacBook is also plugged in an external Monitor which charges the MacBook via USB-C. So it also gets charged constantly. But however it doesnt seem to harm battery life.
Hoped that helped you :)
Greetings from Germany.
Puan 0
Yorum Ekle
Yanıtını ekle
Ivv sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 4,094
