Ana içeriğe geç
The Epson Artisan 1430 is a color inkjet photo printer.
32 Soru Tümünü görüntüle
removing cover artison 1430
I have a new Artison 1430, and want to remove the side panel for waste-ink adaption. On you-tube it shows tabs to be lifted, but my model has a smooth surface so obviously is a later model, and has no tabs showing. I'm afraid a repair manual may not be up-to-date. Anyone can help?
Bu iyi bir soru mu?
Puan 2
1 Yorum
www.baharchap.com
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
OK, it's not very obvious, but the front panel on the right-hand side is just a cover plate` which pulls straight forward for removal. this exposes the 3 front tabs of the side panel, which are easilyprised free, and that allows the side panel to be worked upwards, disconnecting the remaining tabs, and removed.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Comments:
Oh, I forgot: undo the centre and right-hand screws on the lower edge of the rear panel first, then prise the right-hand side of that rear panel to release the rear tabs of the side panel. This should be done first.
tarafından
thanks charles. i wonder what other repair knowledge you have for the 1430, as i get really good photo prints with it. greg wheeler
tarafından
Yorum Ekle
can someone help me i have the same artisan 1430 printer, i tried to clean the printhead by dipping it in the windex maybe too submerged, i installed the printhead started to do cleaning at some point with the printhead almost all the way to the left went off and does not turn on anymore
Puan 0
1 Yorum:
Did you ever get this fixed? Mine won't turn on either.
tarafından
Yorum Ekle
Yanıtını ekle
George August sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 817
