Ana içeriğe geç
Kohler makes the gas powered engines for many different riding mowers & garden tractors both for home owners and professionals.
Engine will run for 2-5 minutes then die
Engine on Kohler powered tractor will start and run for 2-5 minutes then die. It will not crank for 5-10 minutes. After waiting a bit it will crank and then do same. It does this regardless of outside or engine temps. I have run a jump wire to fuel solenoid to rule out the silenoid stopping fuel at float bowl. I've replaced the air filter and checked all fuel lines for crimps. The fuel pump seems to be working also as i can see fuel flow thru the clear housing of fuel filter and it maintains a constant fuel level. I'm stumped.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Take a look at this web site: Kohler Engines See if you can identify the series of your engine and see what the service manual tells you.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I know this is a very old question but it’s the coil.
Puan 0
Yorum Ekle
Try removing/eliminate the fuel filter, sounds like it is vapor locking. If that works, replace it with the small filter that only has a screen in it....it's usually red and is used with lawn mower engines that do not have a fuel pump, but also works if you have a fuel pump. Sometimes those bigger plastic fuel filters will vapor lock after engine runs for few minutes.
Puan 0
1 Yorum:
I had a problem with the gas line being routed to close to the exhaust and fuel was getting to hot in the line and was creating the motor to starve out! Just my personal input from trial and error of trying everything I could think of
tarafından
Yorum Ekle
Yanıtını ekle
Junior Valentine sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 39
Her zaman: 3,903
