Ana içeriğe geç
A Wi-Fi and NFC capable CMOS camera first released in March 2013. Identified by model number EV-NX300ZBQUUS.
My camera can not start after I upgraded it
I have upgraded my NX300 to firmware 1.45 by using Samsung i-launcher but then, I have been faced many problems especially lens (18-55cm III OIS) could not work properly. I fixed the lens error but I could not fix the autofocus by pushing trigger button. Some buttons on the body begun to work wrongly etc. I tried other firmwares to solve out the problems but I could not be successful.
At last, I downgraded it to firmware 1.0 which was original one but now I could not open the camera. It is totally not responding such as dead battery though that it is fully charged.
Is there any way to hard reset it? Or any other solutions to get rid of it??
If someone can troubleshoot my unfortunate problem I will be really really apreciate it.
Thanks in advance.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
Hi did you follow this guide when installing your firmware?
http://www.samsung.com/hk_en/support/skp...
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Try this:
Hard Reset Samsung NX300
Removing the battery and the memory card.
Hold down the Power for 15 seconds.
Insert the battery.
Power on the camera.
Reset your camera by pressing the Menu button > Settings > Reset.
Then try upgrading the firmware again. (if you're game)
P.S. make sure the battery is inserted correctly.
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
Hi @vulkus , thanks for your directions but unfortunately that solution did not solve my problem.
By the way I have tested my battery with amperemeter and it works well.
tarafından
OK just a question though, when you 'turn on' the camera even though it looks like it didn't turn on. If you press the shutter button, can you hear the shutter work? If you can, then try this IFIXIT guide and if it works give that person the kudos.
Samsung NX300 and NX300M Back Panel Assembly Replacement
tarafından
Also have you tried putting the battery in and recharging the camera. Some electrical devices need a battery to pass their assessment criteria. So even though it may appear charged the camera may not believe it is.
If the red light is solid red it is charging, when out charged.
tarafından
It has been plugged to the charger 1 day but still no voice (even when I pushed on the shutter there is no click sound)
When I plug on the charge there is solid red light blink for short period then disappears.
I did not understand exactly what I was supposed to do by dismounting then assemble.
I will try to find another battery to check the body. If it works I buy new battery but if not I guess I will have to deliver it to the service
tarafından
Yorum Ekle
Yanıtını ekle
Cihan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 40
Her zaman: 2,105
