Ana içeriğe geç
Mart 2016'da Samsung tarafından yayımlanmıştır. Model SM-G930V.
Need s7 replacement antenna.
“I'm trying to find a replacement antenna for my s7. No luck so far.”
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Galaxy S7 Antenna Cables (Global)
Replace the antenna cables that connect the motherboard to the charging daughter board compatible with the global model SM-G930F Samsung Galaxy S7 smartphone. Görseli
Ürün
$18.99
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Is that basically the antenna itself? I guess I was mistaking looking for the antenna module. My signal was intermittently dropping completely, for long periods. . Tried all the possible fixes.
tarafından
Those are just the antenna cables that provide the connection from the logic board to the charging port dock flex daughterboard assembly.
The physical antennas are on these parts which are connected via pong spring connectors on the top area of logic board and the charging port daughterboard.
This is for the charging port area:
[bağlı ürün eksik veya kapalı: IF329-024]
tarafından
Yorum Ekle
Yanıtını ekle
Joe Niman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 965
