screen only lights up for a few seconds
screen lights up very dimly for a second, can't read anything on it. Incoming calls work but can't make outgoing calls or access any info contained on the phone. Do I need a new power pack? I see it is possible to buy one from Duracell.
Bu iyi bir soru mu?
Puan
0
Hi,
What happens when you connect the charger to the phone?
Do you get a charging indication on the phone?
Try using the phone with the charger connected and switched on.
jayeff tarafından
Unfortunately nothing, no charger indication and can't use phone with charger connected and switched on.
Elaine Matthews tarafından
Hi,
You could try a new battery as they aren't that expensive. At least it will prove whether or not the battery is the cause of the problem
jayeff tarafından
I will probably do that, thanks
Decided to buy another phone cheaper option but thanks for help
