If your Kenmore 110 Series Washing Machine is making strange noises, see the Kenmore 110 Series Washing Machine Makes Unusual Noises problem page for possible causes and solutions.
MOST PROBABLE REASONS FOR A BUZZING SOUND IN WASHING MACHINE:
Blocked Drain Pump: An object has lodged itself inside of the drain pump. There can be items such as a small sock, a coin, a toothpick, or something small in your clothes pockets when you wash them. These items can fall out of the pockets and end up in the drain pump causing it to become blocked and make the buzzing noise you hear. Here is an audio recording of a blocked drain pump. Unfortunately, the only way to fix this problem is to take the washing machine apart and open up the pump and remove the object causing the buzz sound. To find directions to take your specific washing machine apart, do a Google search for the Make and Model of your washer.
Motor Coupling Broken: The motor coupling has broken and the motor turns but nothing happens. This will also cause a buzzing noise which can also be described as a vibrating noise. To fix this issue you will need to take the washer apart. Here is a video to show you what to look for if your washer motor coupler is broken. Once you know that the motor coupling is broken and needs to be replaced, we recommend ordering the part online. Simply do a search for “washing machine model motor coupler” and you will find the part needed for your specific washing machine.
Washer Drive Block Loose or Worn: The washer drive block is not tight or has worn out. The part will need to be replaced to fix this problem. Here is an audio clip of a worn washer drive block to help you to diagnose that this is your actual issue.
Worn Agitator Dogs: When these are worn, you will hear a clicking or crunching noise. These small plastic parts are used to turn the top of the agitator in one direction. This pushes the clothes down to the bottom part of the agitator to be washed. Here is what your washing machine will sound like when the agitator dog ears are worn. To replace these, order them online (about $5 bucks) and then install them in your washer.
Washer Motor Burned Out: This may result in a buzzing noise depending on circumstances. The way to tell a bad motor is a distinct burning smell. This usually means your washing machine is old and the motor has died from old age. You may need to start thinking about buying a new washing machine. if that is not possible, you can buy a new washer motor for around $100 and install it yourself.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
