Ana içeriğe geç
The first model of the iMac line of personal computers made by Apple. The iMac G3 was produced between 1998 and 2003.
92 Soru Tümünü görüntüle
Glow or light up
I've been given an iMac G3 which is almost perfect. I've put OS 9.2.3 on it which runs fine.
The only problem is the blue shell does not light up or glow?
Searching the Web I came across a statement that there was a bulb somewhere near the round plastic handle but I can't see one.
Anyone know how to get it glowing again please?
Bu iyi bir soru mu?
Puan 1
1 Yorum
Thanks for your help - I must have believed some hype Apple Advert I saw in 1998!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hello,
I was looking up teardown of this particular model and I can't see anywhere the above mentioned light.
If you can provide me the link where you found that it was glowing at some point there is always a way to fix by the way could be steep because of the age of the machine.
You can look up how hard it's even to open this thing up:
https://www.youtube.com/watch?v=j-w-3LZi...
Bu yanıt yardımcı oldu mu?
Puan 3
8 Yorum:
That's modding, the MAC didn't have that built in.
tarafından
You can send the MAC to experienced electrician/computer scientist if you want that the light is powered from inside from the computer. If you want to do it yourself without knowledge for computer science and electricity you can drill(somehow make) the hole and push the led strip inside powering it from outside with a cable.
tarafından
If this answered you'r question please rate it and mark it solved so others looking for this subject know what's going on. Thank you.
tarafından
I thought they were sold in a range of different colours and lit or glowed from new not that they had to be modified?
tarafından
3 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Denny Tuckerman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 389
