How do I fix unresponsive shoulder buttons?
Very simply, the L and R buttons on my DSi don't work anymore. I tried going to Nintendo about the problem, but they said it'd cost at least $50 to repair...and my system is long past its warranty. Will I have to take apart my DS to fix it?
Bu iyi bir soru mu?
5 Yorum
It may have been the yogurt or hot chocolate that got spilled on it, but one of my shoulder buttons is very unreliable. I fixed it by dipping the switch in isopropyl, but it was only temporary.
Brendan Smith tarafından
i took mine apart and sprayed a little WD-40 on the switches, i hope that works for at least a month.
Enno Ader tarafından
YOU &&^&^$^ GENIUS! thank you :) x
Caitlin Agar tarafından
BW-100 is perfect for cleaning buttons without disassembly. It’s non conductive and evaporates quickly. I definitely do NOT recommend WD-40 as it leaves a residue and doesn’t go away without cleaning. If you use WD-40, do so in small quantities and you should definitely clean up any residue and not leave it in your device.
Ian Brown tarafından
You were right, i had this problem for many years and thanks to you i can finally play my games like the way i used to! Thank you very much again for your precious help!
George tarafından
