Ana içeriğe geç
25 Eylül 2015'te Apple tarafından piyasaya sürülen iPhone 6S için onarım bilgileri ve kılavuzları. Modeller: A1688, A1633
Inaccurate GPS while moving
Hello,
I bought used iPhone 6s in perfect condition, but I've got problem with it. I'm a runner and I use GPS trackers a lot. I tried to change the app from Endomondo to Runtastic but there was no effect. My tracking is full of waves and it is "rounded". I installed app called GPS Status. It shows sometimes my position with 10m accuarcy but the most of the time there is +-65m and even if the phone is not moving it shows speed occasionally. What should I do?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Hello,
i would advise you to swap out the internal antenna it's weak and internal antenna isn't so expensive so go for it. Guide and every thing will be down below. If you don't have tools required to oppen up your device i will also post that down below.
Internal antenna:
iPhone 6s Wi-Fi Diversity Antenna
Tools:
Pro Tech Toolkit
or if this is too expensive you should buy this next tools:
Resim
you can find this tools at this link but just scroll down to tools:
iPhone 6s
EDIT:
Forgot to paste the guide link so here it goes:
iPhone 6s Plus Sol Üst Wi-Fi Anteni Değişimi
The original electronics toolkit: Designed for computer, smartphone, tablet, and gaming repair, backed by thousands of free instructions. Görseli
Ürün
Pro Tech Toolkit
$79.95
Replace the Wi-Fi Diversity Antenna compatible with the A1633 and A1688 model iPhone 6s smartphone. Fix unreliable connectivity to Wi-Fi signal. Görseli
Ürün
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Ok, thank you very much. I will tell later if it work.
tarafından Paylaş
I see you are new to this site so if my answer is correct you chose my answer for solution. If not you can wait for someone else to answer. And if some how good point you can up vote it. Hope it works.
tarafından Paylaş
Yorum Ekle
Hello,
I've changed the diveristy antenna, but it didn't help. The GPS is the same inaccurate as it was. Should I check something more?
Puan 0
Yorum Ekle
iPhone 6 Bağlantı Kablosu (Antenna Flex Cable) Değişimi
Puan 0
Yorum Ekle
GPS tracker and network
Puan 0
Yorum Ekle
Yanıtını ekle
Michał Wijata sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 1,487
