Ana içeriğe geç
2011'de piyasaya sürüldü - Core i3-2330M işlemci
No Display dell n4110
Have dell n4110 ..
showing white led on charging
tried all necessary removing battery / installing battery/removing external devices..
still getting white led on battery icon charge..
not powering on..
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Try connecting to an external monitor, if you do not have one see if you can borrow a friend's monitor for testing. If the external monitor can display an image then the problem is with the laptop display, if the external monitor does not display then it is the system board.
Power issues tend to be the system board. If you can open the case and remove all of the RAM and then turn it on, you should get a beep error. If you get a beep error in this case, it means the processor is working. If you are getting an beep error when trying to boot note the sequence, it is usually a pattern of long and short beeps and repeats the pattern.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
vadivel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 429
