Why does the water drain only when it’s empty?
I have a 4 year old front load washing machine. If I run it empty (with no clothes), it goes through the entire cycle and drain perfectly with no issues. If I add clothing, it stops toward the end of the cycle, clothes are still soaking wet and there is water that has not drained. The machine beeps with an error message E21. I have had 3 people look at it. Drain is not clogged. Can’t figure out why it runs fine with no clothes but not with clothes.
Bu iyi bir soru mu?
Is it noisy during the drain cycle?
mayer tarafından
I am having the same problem with my Kenmore front loading washer only I get Code OE. It will fill and drain fine when empty but not with clothes in there.
caraboo7 tarafından
@kj25 did you ever get resolution to your issue? I’m having the same problem. Cleaned out all hoses, ball valve, and bottom drain filter and my washer will not drain and spin with clothes in it. Sometimes I can get it to spin, but won’t drain. Even if it’s half of a normal load. I replaced the water level pressure switch and the washer worked for about 3 loads and then started with the f21 error again. Pull all the clothes out or run a cycle with no clothes and it works.
April Russell tarafından
I have the same problem with front load Whirlpool. Washer. Only spins or drains when empty load. Just one towel in the tub and then error F3 E5. Replaced thermostat, worked for three or four loads then started with error. technician is stumped. 2 year old washing machine.
Upset withwhirlpool tarafından
