Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
Ear speaker low and trebley. Cleaned and Changed speaker, still same!
I havent posted in a year or so because i left the industry, but I've fixed 1000's of iphones.
My wife's ear speaker is very low and shrill. So I opened it up, and replaced speaker. I also made sure mesh was clean. Still the same. Then I took the new speaker and tried it in a different LCD assembly, but on the same phone, and it worked fine.
I went back to the original assembly and rechecked the mesh and hole; clear. This can only mean its something in one of the flexes, right? The other assembly, of course, gives me the fingerprint warning(That it won't work) but she never uses it anyway, but its just perplexing this kind of crap still happens with iphones. Any ideas?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If it works fine in another assembly, then yes. You most likely just need to order a new camera flex assembly. but if you don't want to lose the fingerprint function, then just use the original home button in the other assembly..if you are, then also change the backplate as well where the long Home button flex is attached to.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I just transfered the other to my wifes..thanx anyway...
tarafından
Okay, sounds as if you diagnosed it right the first time:) Best of luck!
tarafından
Yorum Ekle
Yup, It was the Ear Speaker, Prox. Loc, FF cam flex. I took the old one off the other assembly, reinstalled on my wifes, and it works. Ugh, I do not miss this.
Anyone trying this that hasnt before, make sure you heat the front side of the glass just below the FF cam and prox sensor(This will loosen the glue and make it easier to remove), and carefully remove the old with a thin smudger. when installing the new one, make sure everything is perfectly aligned and the cover fits on perfectly. There are no shortcuts and if its not exactly right, and the piece is askew, you can damage your LCD assembly when you put it all back together.
Hope this helps someone.
Puan 0
Yorum Ekle
Yanıtını ekle
Peakcelln sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 268
