Ana içeriğe geç
iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPhone 8, iPhone 8 Plus, iPhone X, iPhone XS ve iPhone XS Max orijinal ürünleri için nasıl-yapılır kılavuzları ve parça değişim kılavuzlarının tamamı.
36476 Soru Tümünü görüntüle
Soru Kapandı
iPhone 3G is dead. The power button is damaged
Hi,
My iPhone is dead. It suddenly went off and I can't charge it anymore. Since my iPhone's power button was already damaged I couldn't do the trick of holding down the power button and home button simultaneously to bring it to life.
Is there any fix for this problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You could try doing a reset by holding down the home button and then plugging it into the USB cable plugged into your computer. That might turn it back on. You will have to restore your iphone when you do that though so if you don't have it backed up don't try that.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
You can try resetting it by holding down the home button and THEN plugging it into the computer. It will come up in iTunes as being in DFU mode and will ask if you would like to restore it. You'll have to restore it and should be able to use the last time you backed it up to put all of your stuff back on it.
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 553
