Ana içeriğe geç
iPod Classic 6. Nesil. Model A1238 / 80, 120 veya 160 GB sabit sürücü / siyah veya gümüş metal ön yüz
Dead iPod- NOT the battery
iPod won't turn on, regardless of whether or not it is plugged into anything. The battery life is still in really good shape and was fully charged at the time it stopped working. Had walked to work with it on, left it in pocket, took off coat, then took out iPod to use in an audio system and it wouldn't turn on. Seems improbable it could randomly die in 5 minutes...
Bu iyi bir soru mu?
Puan 14
4 Yorum
It worked, oldturkey. Thank you for protecting me from my own karma.
tarafından
Thank you for accepting my answer. Wishing you the best of luck and keep on jamming:-)
tarafından
Thank You It worked never thought of the on off button i tried everything else
Thanks Again
tarafından
Your instructions worked miraculously! I really thought I had lost it (and all my recordings) forever. THANK YOU!
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes, they can die from one minute to the next :-) Try to reset your iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
What happens when you plug it into your computer? If this does not work, you may have to take a closer look at it. Let us know how it is going. Good Luck
Bu yanıt yardımcı oldu mu?
Puan 20
32 Yorum:
Had same problem. Solution worked. Thank you very much.
tarafından
awesome...problem solved...thanks
tarafından
Nice. Thank you. Problem solved!
tarafından
Thanks so much! worked perfectly
tarafından
@Matt Tierney, you are welcome :)
tarafından
27 tane daha yorum göster
Yorum Ekle
will I lose my tunes if I replace a dead hard drive on my apple iPod 5th generation
Puan 0
1 Yorum:
Yea as this is where the "Tunes" are kept.
tarafından
Yorum Ekle
Yanıtını ekle
Danielle sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 60
Her zaman: 50,343
