My screen touch does not work
my screen touch does not work i downt know if is the motherboard or the screen touch
can you fix it
Bu iyi bir soru mu?
can you fix it
Bu iyi bir soru mu?
@sathiyamoorthi Assuming you've tried restarting your phone and it didn't help, chances are the digitizer, AKA touch screen, has failed. Since virtually all modern phones have the digitizer bonded to the screen, you'll almost certainly need to replace the screen to fix the problem. Your phone is similar to many Android phones in that there are two ways to replace the screen. The first is the recommended way, which is to purchase the screen already mounted on the midframe; then replacement becomes a case of removing all of the internal components from your phone and transferring them to the new screen+frame assembly. This video shows you how to do that repair.
Meizu M3 Note Disassembly and Screen Replacement - YouTube
If you're not experienced with phone repairs, this is the best way to go.
The other way to do it is to only remove enough parts to be able to access the display connector, then you separate the original screen from the midframe, clean all the old glue off and glue a new display in place. This requires a completely different set of instructions, which you can find on the iFixit guide that one of our users has provided.
Meizu MX3 Screen Replacement - iFixit Repair Guide
The screen alone is only slightly cheaper than the screen+frame assembly, but you may offset that savings by the need to buy a tube of glue, but of course it's your choice as to which way to go.
Good luck, and be sure to come back and let us know which method you choose and how it all turns out!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 28
Her zaman: 243
1 Yorum
sathiya moorthi tarafından Paylaş
