Ana içeriğe geç
Samsung Galaxy Note 4, Ekim 2014'te piyasaya sürülen hücresel bir akıllı telefondur. Galaxy Note 4 model numarası SM-N910'dur; Amerikan varyantları için SM-N910A, SM-N910T, SM-N910V veya SM-N910R4'tür.
Note 4 No Sign of Life
I've been trying to get this Galaxy Note 4 working, and it is showing no signs of life. When it is plugged in, the notification light does not show. I have tried every combination of buttons I've heard, and it won't do anything. It doesn't vibrate, the notification light does not turn on, and the screen does not turn on.
I tested for voltage on the battery terminals with the battery out and the charger connected, and it shows 4.19 volts.
I have replaced the battery with a known working battery, and it did not act any differently.
I'm pretty certain at this point that it's a hardware issue, but what can I check? Being that I'm getting voltage at the battery, I know the charging port is working properly. The only other thing I can think of is something on the motherboard is bad, but of course if anyone has any idea, I'd love to hear them!
Updated with pictures...
Resim
Resim
I just removed the motherboard for simplicity in the picture.
Tested the battery again... It is showing 3.79V. Still no sign of life. Where is PWR7000? And the other things, for that matter.
Update 2: I removed the cover, everything looks to be alright. The scratch on it is just from a screwdriver... my mistake!
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum
PWR7000 is your power switch
tarafından
I got that, I was just trying to see where the power switch leads in order to check for obvious damage.
Post updated again.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@boostedmoose115 follow the troubleshooting flowchart
Resim
Resim
If you need to find the components etc. post a couple of images of your motherboard. Use this guide Mevcut bir soruya görsel ekleme for that
Update (01/20/2018)
for U7000 and most of the components you'll have to remove the EMI shield as pointed out
Resim
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
Chances are power management of needs to be replaced.
tarafından
Thank you for posting, I'll double check the battery voltage and go over the rest of the flow chart at some point today and report back.
tarafından
Updated.....
tarafından
Would the V_BAT voltage be the battery voltage? And what is C7128, and how do I check it? I apologize for all the questions, but I can't find anything telling me what these things are. The the wiring diagrams either don't say anything or it's just impossible to see what they say.
tarafından
I personally don't think note 4s are worth repairing for power ic issues. Too easy to crack the screen on open and already tried replacing multiple chips with no success.
Their prone to going bad on this model again anyway.
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Alex sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 6,194
