Ana içeriğe geç
The 5th generation BMW 3 Series is based on the E9X platform. The car pictured is a E90 chassis. The E9X chassis was used from 2004-2013 when the F1X chassis was released. When talking about a non-specific chassis, this generation is typically referred to as the E9X chassis since there are multiple chassis for this generation of 3 series, depending on the body style (E90/E91/E92/E93).
28 Soru Tümünü görüntüle
Fault code 2A99, crankshaft -exhaust camshaft correlation
I have swapped and cleaned the vanos solenoids, cleaned the filters for the vanos solenoids still getting the fault code and it didn’t swap to the intake cam when I swapped the solenoids
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Have you checked the Vanos bolts? Call your local dealer and tell them your VIN. Ask them if you have extended warranty on Vanos adjuster units. You can take the valve cover off yourself and check the bolts
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Robert sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 21
Son 30 gün: 53
Her zaman: 3,379
