Ana içeriğe geç
Wear OS kullanan akıllı saat Asus ZenWatch 3 için onarım rehberleri ve sorun giderme bilgileri.
Crown does not working (mid)
My watch works perfect, but the Crosn button is not working.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had the same problem so took the watch apart with a torx 4 and discovered that the plastic press that the crown pushes against was cracked so being the handy feet thinking female that I am I repaired this by glueing a fragment of false nail over it (with nail glue)
Resim
Resim
And now reassembled it works perfectly fine
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
I tore the watch down to look at how the buttons work. While the others distinctly click, the middle/crown button felt mushy. I found that if I applied pressure to the circuit board while pressing the crown button, it would click. I put the watch back together and found this to still be true. When the crown button doesn’t work, if I squeeze the watch, face to back, and at the same time press the button, it works. Not an elegant fix, but it works.
Puan 1
Yorum Ekle
Yanıtını ekle
Sandro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 30
Her zaman: 1,161
