How do I know if the front CV axles are bad or the bearings
The driver side axle meets the inner shaft in wat looks like to me a carrier bearing then the shaft goes to tranny. Where my CV axle goes into the carrier bearing it has some play. You can shake it a lil bit by hand. The passenger side axle torge the tranny is throwing grease. The vehicle has over four hundred thousand miles on it also
Bu iyi bir soru mu?
