Ana içeriğe geç
2nd screen replace still wont sense touches on screen-cant unlock phon
so i cant swipe to turn it off and I cant input pin number to open the phone as it DOESNT SENSE THE TOUCHES FROM MY FINGER, like at all. Had the screen replaced once for ghosting. 6 months later it senses no touches at all. I replaced screen bought from IFIXIT and it worked for one pin insertion then stopped working again. Is there another component that senses the touches of the finger?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This mostly happen in iPhone 6 plus.I think this is the common fault in iPhone 6 plus.First you have to restart the phone by pressing home and power switch.If the problem still same try to change other LCD. After
changing if the fault still same clean the touch connector.
Finally if you all doing and still same no dought that is the fault of Touch ic.
Rehot touch ic first -Mostly fault solved otherwise you have to change touch ic.
Update (02/16/2018)
This two ic are stands for iPhone 6 plus touch ic.
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
what is a touch ic?
tarafından
how does a person rehot touch IC?
tarafından
[image|1344121]
These two ic`s are the touch ic.
tarafından
Reflowing touch IC is only a temporary solution the touch IC needs to be replaced.
Usually the meson main one needs to be replaced, sometimes cumulous as well.
tarafından
Yorum Ekle
Yanıtını ekle
Art sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 56
