Ana içeriğe geç
Fujifilm Finepix S4200, Fujifilm tarafından 2012 yılında piyasaya sürülen 14,0 megapiksellik bir köprü tipi dijital fotoğraf makinesidir.
On off button sticking and stiff
My on off button seems hard to move and sticks in postioymoved to it used to just spring back by itself
Bu iyi bir soru mu?
Puan 0
1 Yorum
Tried it made slight difference button still not working properly one of the kids must of dropped it as it still doesn’t move back itself as it use too but thanks for your suggestion will probably have to take it to a repair shops
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like a button that is physically stuck, like you said, get a bottle of Isopropyl Alcohol and a Q-Tip, dip the Q-Tip in the bottle, gently swap the switch with the wet end of the Q-Tip (make sure the device is off) switch back an forth. Rinse and repeat until the switch is loose again. Hope that helped!
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Where can I purchase a new button. My button came completely off?
tarafından
Yorum Ekle
constant problem with these cameras. even lubrication does not help
Puan 0
1 Yorum:
I put new batteries in the camera and won't come on
tarafından
Yorum Ekle
Yanıtını ekle
gazza b sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 3,276
