Ana içeriğe geç
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Screen goes extremely dim
My screen is almost always extremely dark (no icons visible just very dim light) sometimes it helps to hit it on the back a few times for a few minutes but then it goes flickering/ green to black again. I also tried reset and completely reinstalling it without luck. I guess the LCD cable is loose? How much would a repair cost?
Edit: sounds like a backlight problem according to a local repair shop, he said repair costs 120€... is it possible to fix it by myself, without technical super skills?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Depends. It could be the LCD going out (which is a DIY) or a backlight coil, which would need micro soldering.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks for your answer! "LCD going out" means I have to buy a new LCD screen for109$ ?
I wonder if I could fix it somehow with a harder hit on the side as the screen works perfectly sometimes...
tarafından
You should have a warranty from your supplier.
tarafından
Yorum Ekle
It is better to fix it hitting it just rigs it to work for a while just replace it alway the way to go. And how about having the lcd tested on another I pad this will help diagnose what the issue is!
If you have any questions or concerns please comment below. Thank you
Puan 1
Yorum Ekle
Yanıtını ekle
Bastian sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 33
Her zaman: 482
