Ana içeriğe geç
Pebble 2, Eylül 2016'da Pebble Technology Corp. tarafından piyasaya sürülen bir akıllı saattir ve orijinal Pebble Watch'un yenilenmiş bir versiyonudur.
Is there any replacement for the button covers?
I just had the lower right button cover crack and fall off. Does anybody know of any ways to get a replacement rubber panel?
Has anybody taken the watch apart to see if it's even possible to do this sort of replacement?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 9
2 Yorum
Thanks, Those shapeways links were useful. It took a bit of hand fitting, but those button panels work and now my favorite watch is running again after being idle for far too long.
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I know the original question is an old one, but since a lot of pebble 2s eventually have this problem, here’s a link to my 3D buttons and cases on Shapeways.
https://www.shapeways.com/shops/astosia?...
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Update, if Shapeways’ postage is too high, you can buy buttons from the website now too.
https://favouritehumandesign.com
tarafından
Yorum Ekle
I had the same problem und found this site, with printable 3D Models:
https://www.thingiverse.com/thing:259955...
Puan 1
Yorum Ekle
https://www.shapeways.com/product/UAMY5G...
Requires OG Pebble parts, but this may be a good fix.
Update (07/06/2021)
I found this just now, I have two P2HRs that both need new buttons, but I think this may be an easier fix. https://tinyurl.com/k8a5h6na UPDATE (08/05/2021) I bought the version with the battery and glue. It’s a fairly easy transfer. Requires a Soldering Iron and some steady hands, but the fix was worth it! Don’t forget to transfer the microphone seal from your old case to the new one, and use A LOT of glue to get the back sealed back up!
Puan 1
Yorum Ekle
Bonjour, j’ai trouvé plusieurs sites qui vendent des boutons.
https://www.shapeways.com/product/ANHBW4...
https://www.shapeways.com/product/4Q27VC...
https://favouritehumandesign.com/product...
Puan 1
Yorum Ekle
I have resolved with this:
"2 Smart Watch custodia originale in ePaper con pulsanti laterali in gomma e pannello in vetro Gorilla Corning - AliExpress
Puan 0
Yorum Ekle
Yanıtını ekle
Frank Scheers sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 16
Son 30 gün: 41
Her zaman: 7,568
