Ana içeriğe geç
A Kenmore residential washing machine made between 2001 and 2009. Identify the age of your Kenmore washer with its serial number.
Smell from washer is overpowering...how do I clean the machine
Are there steps I need to take to clean the machine?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Run a rinse cycle with a gallon or two of Vinegar poured into it.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
One other thing, to do with all washers today, is leave the lid open when not being used especially front load washers! Also there is a clean cycle on front loads that will pop up on your display and tell you to run a clean cycle. This needs to be done whenever it’s noted on the washer. Unless of course you want a horrible odor in your laundry room and house. This eliminates mold from growing in the bottom of your washing machine tub .
tarafından
Yorum Ekle
Your washing machine's drain pipe might have a partial clog that you might not have noticed before. A clog in the drain line will often produce an offensive odor that can resemble sewer gas because the bacteria can form on the organic matter likehair or soap will often produce a nasty smell.
here’s a video on other solutions:
https://www.youtube.com/watch?v=1X2vgob4...
Puan 1
Yorum Ekle
Yanıtını ekle
Bob sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 538
