The Dodge Dakota was developed by Chrysler as a mid-sized pickup. To keep investment low, many components were shared with existing Chrysler products and the manufacturing plant was shared with the full-sized Dodge D-Model.
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
1 Yorum:
Check all your wiring at the sender. Make sure you are getting a good earth signal. aka clean earth point. Also see if you are getting any power. Unless it has a fuse for it, which might be unlikely. Find which wires run to your fuel gauge on your cluster and trace to wire harness again see if you have power and earth. It could be that your sender unit is dead, but best to check everything else first.
sm_vulkus tarafından
