Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
New battery gets hot and discharges too fast
Battery replacement went okay, even replaced the screen gasket. Battery charges to 100% but discharges quickly. Front and rear are warm when the phone is just sitting on the table. Battery discharges in about 4 hours, even if not using phone at all. It’s not even logged into an iCloud account (it’s wiped and just sitting at the default home screen or the screen is off). There are no apps installed, just a default reset. Must be a short somewhere but any clues how to find it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Did you experience similar issues before the replacement? Is that the reason you went to replace battery?
I would try another battery, if that doesn’t work, you may have a damaged tristar chip, this is usually damaged from cheap cable usage etc. And would need someone who can microsolder on a new Tristar chip. :-)
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
ericrose62 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 468
