Need Advice on Re-soldering Battery Connection to Motherboard
Hello wonderful people of ifixit.com,
I attempted to disconnect my battery from my Asus Strix GL702VM laptop, by following this tutorial from a community member.
However, one simple oversight in the tutorial led me to rip the motherboard connection to the battery. (As seen in pictures below)
The laptop still works perfectly fine, except it now has no battery (evidently)
Is it possible that the connector could be Re-soldered to the motherboard, so I can use my battery once again? And if so, is it better to do it myself, or to outsource it to some specialist (bearing in mind I've never touched a soldering iron before)
Any help would be appreciated,
Thank you
P.S. Apologies if this post is a little long
(This last image is where I've tried to line the connector up to where it's meant to be. )
Bu iyi bir soru mu?
