Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
iPhone 6 only charges while on.
If the battery ever drops to 0% and turns off it cant be turned on or charged. I have to take the battery out boost it then put it in and turn it on, where it will charge just fine. Confirmed issue on multiple batteries.
Could this be Tigris or Tristar IC?
I do motherboard repair all the time so microsoldering is an option I just want 2nd and 3rd opinions before I go replacing IC's.
Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
4 Yorum:
Faulty charging port?
New charger?
tarafından
No, tried second charge port same on multiple chargers.
tarafından
Hmm... Maybe try a battery replacement then.
tarafından
WAIT....I see you already tried those....Hmm...A lot of people at my school have a similar issue with their chromebooks. I can ask one of the technical people there and see if they have a better answer.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Tristar chip needs replacing.
If you want you can unplug battery then plug in charger, if it doesn't show apple logo then Tristar is bad.
In some extreme cases you may even need to change charger port after tristar replacement as they can go faulty at the same time.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Trent Quan-Sing sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 723
