Ana içeriğe geç
Acer Aspire 5750 için onarım rehberleri ve sorun giderme bilgileri. Bu, 2012 yapımı, sıradan ev kullanıcılarına veya küçük işletmelere yönelik uygun fiyatlı bir Aspire dizüstü bilgisayardır.
No power from DC.
I was using this laptop and the power died. I realised that it had been running on the battery although the DC mains cable was plugged in. The battery had run out of juice.
There was no DC power LED on indication
I have tested all the obvious things, and have now replaced the DC cable and socket with a new one.
However when I plug it in I still get no DC power LED on indication. Currently the keyboard is removed and I haven't bothered to put it all back together as there doesn't seem any point.
Does anyone know what to try from here ?
Many thanks in advance.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum
@oldturkey03 the DC power adapter chucks out 12v. This is still working.
tarafından
usually dc output is 19v is it not
tarafından
yes, 19v. I think I'm using the wrong adapter. so much for "I've tested all the obvious stuff". Thanks for the wake up call, dang.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@sponge_bob you wrote that you "tested all the obvious things," but did not tell us what the output of your AC adapter is. Should be a 19V 65W adapter
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Sponge Bob sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 404
