Where is the thermal sensor in my MacBook A1286?
The diagnostic tool AHT tells me following issue:
"4sns/1/c0000008: TAOP--124"
When starting the macbook the fan's go up to 6000rpm and kernel task eats around >600% CPU.
Can someone help out where the sensor is to that i can check connectors or try to fix it?
Thanks,
Artur
Bu iyi bir soru mu?
Puan
0
@online_guru TA0P is for Ambient Temperature Sensor
T = Temperature
A = Ambient Temperature
Did this just happen or did you work on your MBP?
oldturkey03 tarafından
I have changed the display unit, you know where the sensor is located?
Artur W. tarafından
