Ana içeriğe geç
Signet serisi, Kodak'ın 1950'lerde Amerika'da üretilen en üst segment 35 mm fotoğraf makinesi serisiydi. Bir mesafe ölçere sahip sadece iki Signet modelinden biridir ve gövdesi büyük oranda plastikten yapılmamış tek modeldir.
Why triangle patch is not visible when view through viewfinder
where could I buy a new one beam splitter ,because the coating of beam splitter does not exist and when view through viewfinder the triangle from the rangefinder is not longer visible , and i try using a piece of blank 35mm color negative that has been processed which I put behind the beam splitter, and followed these procedures the triangle of beam splitter is visible , but appears as double triangle, probable first triangle is a reflection of 35mm colour negative film procesed , and the second triangle is reflection of beamsplitter glass.What do you think.Thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Your beamsplitter got mis-aligned. Review this IFIXIT guide: Kodak Signet 35 Işın Ayırıcı (Beamsplitter) Değişimi. There should be a couple of small setscrews which has some glue on in to prevent it from shifting. One is to adjust the parallax (up & down) the other the infinity set.
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
tarafından
This is such an old camera parts will be difficult to find. Maybe you can find a second non-working camera to steal the part from to fix yours.
tarafından
Thank you very much
tarafından
Yorum Ekle
Yanıtını ekle
Florentin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 443
