Ana içeriğe geç
Designed in 2005 and released for the first model year in 2007, the GMC Yukon is a five-door SUV. It is a rebranded version of the Chevrolet Tahoe, both of which are designed by General Motors.
13 Soru Tümünü görüntüle
How do I change the oil pressure sensor in my 2011 GMC Yukon
What is the easiest way to change the oil pressure sensor in a GMC 2011 Yukon I can't afford to pay 400 dollars to have a 30 part put in and I'm pretty good with tool I just don't know how to do this or where it is
Bu iyi bir soru mu?
Puan 0
1 Yorum
If Cartalk where still I'd direct you to those guys.
But they're not. @jimfixer or @jayeff may be able to help.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Depending on the motor thats in the truck it can be a difficult job . you will need a special socket to do the job. This video will help some . Its a very tight spot to do. On the 6.2 it requires you to remove the intake manifold so it can start to rake in a lot of time. It is a job that could be a little easier if you have small hands . Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Can be done without removing intake
Puan 0
Yorum Ekle
Yanıtını ekle
nicole parsons sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 58
Her zaman: 8,991
