Ana içeriğe geç
Released October 2016, identified by model number RS03QR
I am unable to hear alexa's responce to my questions
I just set up my dot about a week ago. It was working fine as far as we were able to hear Alexa's response. However I just noticed that we are not able to hear it but the light does turn on and if I open my app on my phone I see my question and response. I have re-connected my wifi as well and still no luck.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
4 Cevap
Filtre ölçütü:
Smart speakers are not perfect devices, users face or run certain problems with them from time to time. If you are getting trouble Alexa not hearing your voice-commands or not response to your question then try this one:
- Light ring sholud not be red because the mute switch at the top of the smart speaker has been activated, that's it is not hearing your commands.
- Second reason is due to interference. If echo dot not listen your commands, then place it right location and away from walls and others objects.
- After this problem occuring, possibility that microphone array of echo is malfunctioning.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
First, you want to make sure the volume on the Echo Dot is turned up. If it’s not, use the + and - buttons to control the volume. If it still does not work, make sure no 3.5mm AUX cable is plugged into the Dot (if it is, it will be on the back. Unplug, or make sure the speaker it’s connected to is on and the volume is up). If things still aren’t working, make sure your Echo Dot is not connected to a Bluetooth speaker. You can do this in the Alexa app, or by saying “disconnect my speaker” to your Echo Dot.
Hope this helped!
Puan 0
Yorum Ekle
Have you checked is your Alexa not responding but lighting up? Alexa lighting up in white color but didn't receive your voice commands shows that it were stuck on somewhere.
Try these troubleshooting tips:- https://smarthomepassion.com/alexa-not-r...
Thank me later
Puan 0
Yorum Ekle
I can’t hear her voice
Puan 0
Yorum Ekle
Yanıtını ekle
Veronica Duarte sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 3,674
