Ana içeriğe geç
iPad Mini 2'nin LTE sürümü için onarım rehberleri. 22 Ekim 2013 tarihinde duyuruldu ve 12 Kasım 2013 tarihinde piyasaya sürüldü. Başlangıçta Retina Ekranlı iPad mini olarak bilinen iPad mini 2, iPad Air'in tüm piksellerini daha küçük, 7,9 inçlik bir form faktöründe sunar.
Is this a battery leak?
I opened an iPad Mini earlier to replace the screen and found a shiny coating on one end of the battery. Does this look like a battery leak?
The coating is already dry and feels fairly smooth. It only appears along the top of the battery along the edge that's exposed under the LCD shield plate. There's no sign of fluid below the battery or elsewhere in the iPad. This device has been repaired before.
If it's not from the battery, is there anything else in there that might leak? The LCD looks fine. There were no reported battery issues, either.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
That does not look right.. Looks like something melted at the bottom of the battery.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yes, you will probably have to replace the battery and any components that have been damaged by the leakage.
It looks at though the battery acid has dried up.
Puan 0
Yorum Ekle
Yanıtını ekle
Ket sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 1,436
