x-box controller not connecting to console
on/off light flashes but dose not connect to console . was working earlier. changed batteries. did not help
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You should manually pair the controller to the Xbox. Use this link to help you.
Bu yanıt yardımcı oldu mu?
tried your link. did not work.. I have had my x-box 1 for about a yr. the controller was working earlier in the day, turned x-box off tried to turn it on a couple hrs. later. it did not turn on the console. I turned console manually than turned on controller. the on/off button just flashed. changed batteries. did not help.. stumped :(
Well I would just assume the controller is done in for and buy a new one. Microsoft doesnt say much about this.
i am also having this problem. .with all 4 of my controllers..none of them will connect..fresh batteries nor resyncing did any good. .worked absolutely perfect last night
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 3,493
My controller is not sync with xbox 360 even I attempted alot to restart, sync button press for both controller and console but unable to find solution.please help even I refixed hard disk also
maryam waseem tarafından
