Ana içeriğe geç
2010 ve 2011 yıllarında piyasaya sürülen G73, Asus'un bir oyun dizüstü bilgisayarı serisidir. Model numaraları arasında G73JH, G73JW ve G73SW bulunur. Tüm sürümler, Intel Core işlemci ve grafik kartı kullanır.
How to fix battery/charging issue with laptop?
For whatever reason, I can no longer use my laptop on the go anymore. My power adapter needs to be plugged into my laptop for the laptop to power on. I replaced the battery but that does not seem to change anything
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check the power icon on the taskbar. Does it show the battery charge state?
Download and run BatteryInfoView from https://www.nirsoft.net/utils/battery_in... and see what it says about your battery. This will give a more detailed view. Also, see what it says about your old battery.
These are smart batteries. If it doesn't detect either then you've got a fault on the motherboard in the communications path to the battery.
Otherwise it should show the charge state. If it's showing as discharged and not charging, or as charging but the charge state never improving it would seem to be a problem with the charging circuit on your motherboard.
A motherboard fault would be difficult to diagnose and fix, but it may be simply that your new battery is a dud. BatteryViewInfo will hopefully tell you that. If so, go back to where you got it and ask for a replacement.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I did just as you said and looked at the charge state and it seems to show that the batter is at a 28% charge and plugged in and charging.
Looking at BatteryInfoView, as you can see (https://imgur.com/a/Jp7x8) if shows that the battery is okay but there is some missing information that it cannot take into account like battery temperature and serial number but I'm assuming that that could be normal.
tarafından Paylaş
Yorum Ekle
WOW, I feel stupid! For years I’ve been dealing with this too. Different batteries, chargers, tested against known good hardware, I honestly thought custom vBIOS and System BIOS were the issue, or just carelessness reassembling after repasting the heatsinks and cleaning.
All that i needed to do was “Lock” the battery in. The slide release didn’t keep it connected well enough.
Puan 0
Yorum Ekle
Yanıtını ekle
dco4235 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 2,802
